The Compaq Mini 110 is a lightweight portable laptop created by Hewlett Packard (Hp) as part of the mini series. This page provides repair information about the Compaq Mini 110, as well as helping users troubleshoot and fix issues with their device.
14 Questions View all
Tells me to install a programe
My compaq mini 110 won't turn on properly, it gets to before the log on page and says that i need to install a Windows programe then it turns off but i'm not sure which one and where to get it from, i really need this fixed as i have all of my college work on there! :( PLEASE HELP!!!!!!
Add a comment
Chosen Solution
Vanessa, you could try and go into your BIOS and start from another operating system. That way you could recover your files. The other thing you can try is to repair your Windows version. Try to access the recovery partition of your Compaq mini 110, here's a step by step procedure :
Turn off your computer
Except for the mouse and keyboard, remove all other USB devices.
Turn on your computer and start hitting "F11" key repeatedly until you see a different screen.
Follow the onscreen instructions until the recovery is completed.
Score 1
Add a comment
Hi,
In this case it would be best to perform a system restore.
There are two ways to perform system restore:
Open start menu click run and then type cmd to open command prompt.
Type CD.. to make c:\ only.
Type CD windows then CD System32 and then restore.
After once you find yourself in c:\ windows\system32\restore>
Then type restrui.exe press enter.
Once the system restore window open then click next to select any available restore point.
This process shall take couple of minutes to perform restore and please make sure that once this process started it wont be reversible and neither you will lose any personal data.
Other way to perform system restore is to open safe mode by clicking F8 on start-up and check safe mode option then further a dialogue box will open to ask for system restore and then follow the above steps. Thanks
Add a comment
Add your answer
Vanessa will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 509
