PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
69 Questions View all
Laptop not turning On when pressing power Button
When I press on Power Button only the media player touch LED blinks once and the light for caps and numlock continuously blinks even I can see power on DVDROM and fan too moves . But none of the LED in front blinks and no power on monitor is there.
Could you please suggest me what should I do.
Score 2
2 Comments
can you attach an external monitor and see if you get anything? Any post beep's?
by
Use this : Dell AC Adapter LA90PM130
by
Add a comment
Chosen Solution
Thanks for your Suggestion "oldturkey03"
I have troubleshooted it and found the reason, its because one of my RAM has gone Bad.
Regards,
Amit Lal
Add a comment
Some times the Heat sink & fan gets dust and due to which system gets heated.
Once cleaned can help overheating & abnormal switching off issue.
Add a comment
Add your answer
Amit Lal will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 11
All Time: 4,028
