First-generation Apple iPad with 3G capabilities. Model Number A1337. Available with 16, 32, or 64 GB of storage. Repairs are straightforward and do not require heat.
My screen doesn't rotating.
Hi,
My ipad wont rotating, i've done all things but still doesn't work. might some problem with the hardware, do you have any idea where the rotating sensor located inside the hardware?
Thanks Bernie,
Score -1
Add a comment
Chosen Solution
I know this is an old thread but sometimes it's a simple thing of changing lock button on upper right side of iPad to be " mute" . Go to settings, general and scroll down to lock button either lock rotation or mute. Select mute
Score 2
Add a comment
Most Helpful Answer
Hi, just trying to help. Have u read this?
https://discussions.apple.com/thread/398...
Is this of any help? Do you have the same problems as described. If it is a faulty sensor then you will need to have a hot air reflow station to do the repair. Better to go in an Apple store.
Score 2
2 Comments:
Thanks for the link John, but i already done all of that options but still won't work. I am pretty sure that my iPad 3 gyroscope sensor is the problem, i just want to know where is it located inside. i hope somebody could help me to share the picture of it.
by
Add a comment
Add your answer
Bernie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 5,014
