MacBook Pro models with a 15" display
How to fix a dented corner?
I dropped my mac book pro 15 inch and it has a dent on lower right corner and a scratch on the upper lid near the screen ,i am so heart broken ! i Live in Iran where i cannot access a Genius bar or ebay store to buy a new lower lid i want to know how can i fix it ?
Mac book pro 15 inch
Serial Number :*********V7L
Plz help
Score 1
Add a comment
1 Answer
Chosen Solution
You need to replace the top case. Fairly expensive part, and if you have never repaired computers, you should probably not attempt this repair on your first try! It requires you to gut the entire computer basically. But there is a guide on here that will do it step by step! If you do be careful and good luck!
Pat
Score 1
2 Comments:
if i just ignore the scratch on the upper lid near the screen how can i fix the lower lid and i have asked some repair guys down here and they told me if i open the case there is chance that my mac never boots up again due to damage to the main board !
by
and what is inside lower right corner ! i wanna know if there would be a crack in the main board they ve told me if you open it up since its now fixed together its working but in case i open up the lower lid it may fall apart ----now everything is working just fine ! or it looks fine to me except the light on the right lower corner which is turned off (there are 2 lights the longer one is turned off but the little one works
by
Add a comment
Add your answer
gesges will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 10
All Time: 7,986
