Model M7886 / 450 MHz or 500 MHz PowerPC 7400/7410 (G4) Processor
17 Questions View all
change cd drive to dvd -r/w, and airport card possible?
I have a Power Mac G4 Cube and I would like to put a DVD-R/RW drive to replace the CD drive. Is this possible? If so what model drive should I buy? Also,I'd like to put an airport wifi card in the machine as well... is the new Airport Xtreme compatible, or should I use the older Airport card?
Thanks
Score 1
Add a comment
Chosen Solution
Hi, you can put a DVD Drive in (not sure about disc burning though), as shown here:
But you can only have an Airport Card (not Extreme):
Hope that helps
Score 2
3 Comments:
just out of curiousity- what app is that?
by
MacTracker
by
This is an old comment, I know by now, but thanks anyways.
by
Add a comment
Actually you can as long as you remember these things the wireless is going to be limited to a or b connectivity only because it uses the older airport card as long as the drive is slot loading it really doesn't matter because you can remove the ice adapter off of the back of the current drive and attach it to any drive
Add a comment
Add your answer
Gaspar will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 15
All Time: 3,260
