web cam for iBook g4 1.33
Hey there. I tried to connect regular window's webcam , it didnt work. So tell me , please, do i need some special web cam or i do something wrong in connection?
thank you . Mike
thank you . Mike
Your best bet for compatibility is a used Firewire 400 iSight. These are not hard to come by despite being long discontinued.
If you do not wish to get a used camera, most USB webcams work with OS X without explicitly saying it, but they may be few and far between. Try and find one that's advertised to work otherwise make sure it comes from a store with a solid return policy as insurance.
The Macally IceCam2 webcam works pretty well with my daughter's iBook G4 1.33Ghz under OSX 10.5.8. It's a USB 2.0 webcam so it won't work with Macs using the old USB 1.0 technology.
To use iChat (or any other video chating software), you need a FireWire 400 webcam (Preferably an Apple iSight) and a FireWire 400 port (Which your laptop should have). External USB webcams are not supported in Mac OS X.
thank you :)
Any webcam that is UVC (USB Video Compliant) should work. You will need to be using at least OS 10.4.9. Personally I use a Logitech, QuickCam Deluxe for Notebooks, and it works fine. But be carefully, older versions of the Deluxe model do not support UVC. Look for a model that is VISTA compliant, that should also be UVC compiant. You may want to pick up a copy of iGlasses, the software will give you a lot of control over the webcam image.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 4,576
