Repair and disassembly guides for hundreds of optical disc drives.
31 Questions View all
Can the optical drive from an A1095 be installed into an A1150?
The optical drive in my MacBook Pro A1150 died. I have an old PowerBook G4 A1095. Can I install the optical drive from the PowerBook into my MacBook as a stop-gap measure?
Add a comment
Chosen Solution
The optical drive from your A1095 PowerBook is too thick to fit into your MacBook Pro, unfortunately. Of the original MacBook/MacBook Pro line, only the 17" MBP's can accommodate the 12.7 mm thick drives.
Sorry!
Score 3
1 Comment:
+1 Ralph
by
Add a comment
The PowerBook G4's use PATA Optical Drives, and most likely has a 4X or 8X SuperDrive. The A1150 appears to be a PATA drive as well. It should be compatible, unless the thickness is a problem.
Score 1
Add a comment
Add your answer
micgreyer will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 21
All Time: 1,756
