How can I get new screen for nexus4
my Nexus 4 has broken screen.The LG told me if you buy new one it's better than fix your nexus .
When you have a new screen you can use this guide to replace it. If you buy a new screen without the frame, you'll need to remove the broken screen from the metal frame. I'm uploading a video for this in a few days
So, if the display is still working, showing colors and light.. You *CAN* conceivably just replace the front glass AND digitizer.
However, this requires separating the front glass and digitizer from the LCD, without harming the LCD. Read: using heat to separate strongly glued together glass components.
It's a pain in the butt.
Really, get a new screen, LCD, Digitizer, front glass, at least. Preferably already attached to the frame/housing.. otherwise you have to unglue your current housing from your broken screen, and then re-glue it to the new one. (not fun).
Well that would depend on how much a new one would cost you, here is a link to your screen, they are expensive because you have to buy the LCD Digitizer together, good luck, https://www.gounlock.com/search.php?prod..., If this answer was helpful please remember to mark it accepted.
hello,
you can try to get it at www.togytech.com
they have the full version including the LCD, touch , Battery and all the parts on it.
you just Plug and play.
very easy and good service
I just dropped my phone. The screen is cracked, wont register any touches.
What do I need to replace?
Hello,
i also dropped my nexus 4, it was a little drop but the screen has one scratch (not a big one) but the touch working in some places in the screen and not working in other places.
can anyone advise me which part should i change?
thanks.
Hi Mina,
Now am facing same problem. Display is working. but touch is not working. Have you got repaired your mobile?
How much cost?
did you have any luck replacing the screen?
i am having issues with my nexus 4 screen touch,so looking for replacing it
same here how much does it cost approximately???
Same here - display is perfect but touch is not recognized at some screen area horizontally (center of the screen) as well as vertically (right of the screen) while the touch is recognized at most of the parts. While typing I have to use my handset as the car steering to be able to pick some of the keys :) Still looking for a firm solution, can anyone please help me.
Hi friend, you can check below link
http://www.eddogo.com/catalogsearch/resu...
You can get all of Nexus parts
If you have any install problem, also can contact me anytime, thanks
I would like to buy the kit myself and fix it myself where can I buy it at
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 7
All Time: 47,448
