First-generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB. Model Number A1219. Repairs are straightforward and do not require heat.
Dropped iPad can't charge anymore
I dropped my ipad at the button and know I can't access the charging connection because the metal frame is in the way. Is there anything I could do?
Update
I actually got it to power on but I can only get a black screen with purple, blue and green line everywhere and it seems like the LCD is cracked but my digitizer is perfectly fine. Do you think changing the LCD would fix it?
Score -1
Add a comment
1 Answer
Most Helpful Answer
The only thing you can do is try to bend it back, if you can't fix it you wil have to replace the back cover. A very difficult task..
Score 1
Add a comment
Add your answer
Philippe Dupuis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 447
