Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
784 Questions View all
Procedure on how to clean the Logic Board with isopropyl alcohol?
I have a MacBook Pro 13 2011, how I proceed with cleaning the logic board which was subject to water damage?
And how do you precede with cleaning? Using cloth or how?
Saw a topic on this page Cleaning a logic board......
Thank you
Score 4
Add a comment
Chosen Solution
Here's the guide for doing this: Electronics Water Damage
Score 2
Add a comment
Aslamualikum dear brother i used mother bord cliner fine product
1 Comment:
Hello Brother can you pls help,need advice
by
Add a comment
Genius Guy, recommend you first open your system and get 99% alcohol to clean the board, dont be scare to take a pane with alcohol and clean the board using a tooth brush getting wet the board it will be ok for Apple boards but not for pcs, leave it for 20 mins, alcohol is acting under chips, then blow it up with regular compressed air, if you are in a hurry blow it up after with hot air, make sure you dont create static electricity, then wait for one hour inspect board again before turn the computer on again.
1 Comment:
HI need help , i spill hot milk in to mother board , if i clean as u said its will work and won't damage the board.
by
Add a comment
Add your answer
Martins Strobinders will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 30,142
