Updated version of the Kindle Fire 7" tablet by Amazon with 1280x800 HD display. Released September 2012. Repairing this device is straightforward.
My kindle won't turn on. Is it the battery?
I walked in one day and my kindle fire hd refused to turn on. I've made a visual inspection of the motherboard and battery nothing seems out of sorts. Is there a way to tell if the battery itself is the problem or if there is something else i can try. I am not terribly concerned about the fire itself, there is a good amount of data on the harddrive that i need to get off. I'd love to get the fire working again but the data is more important. Is there anyway that i can get the data out? or tell if the battery is working so that I don't waste my money trying to fix it.
Score 66
42 Comments
Help me now I need help
by
Bang it on the ground, then hold the button down thirty seconds. Press the button
once again.
by
My 3rd Generation Kindle Fire went dead. Won't seem to charge or just has a black screen? I had two. Here's what I did. I carefully slipped a sharp knife in the slit where the case splits and took the back off. I then slipped the connector for the battery out of its receptacle. I slid the metal knife edge across the metal contacts on the battery plug and plugged it back in. My Kindles both immediately booted up and worked fine. Pretty sure this voids the warranty but at this point what matter does it make? This happened to both of mine exactly 30 days after the warranty ran out.
by
I also tried passing a metal knife across battery contacts after reading this post and it really worked right away instantly on my son's 3rd Gen kindle fire in which froze on three different occasions through the years which I fixed using 30 second power button hold or holding volume down/power button master reset I even personally changed its broken usb port last year. Thanks who ever you are it really worked after other proven methods were not working anymore this time around
by
My kindle Fire has gone dead and all my efforts to revive it have failed. what is distressful is that Amazon which is selling these devices in India is least concerned about it,and i am told they donot have any service center in India
by
Show 37 more comments
Add a comment
Chosen Solution
PART 3: ANOTHER REASON FOR KINDLE FIRE LOCK-UPS
Probably the number one reason Kindle Fire (KF) devices lock-up is because the battery discharges. When using a wifi connection you should connect the KF to a power supply outlet or USB port on a PC computer, or use the KF only for a short period of time when away from a power source. When the battery runs down it will usually cause a lock-up. Simply connect the KF to a power supply source and recharge the device. It is best to turn off the device and let it charge. If it is locked up, you will need to hold the on-off button for 15-25 seconds to turn it off. A red light at the on-off button shows the battery is discharged. A green light means the battery is fully charged. It is a good idea to charge the battery for at least four hours before using it again without a connection to a power supply source. Always check to see that you are disconnected from the wifi when operating off the battery supply except for short periods of time, otherwise when the battery runs low the KF will more than likely lock-up.
END OF PART 3
Score 23
17 Comments:
I keep holding it down for 30 seconds and i wont turn on
by
I have the same problem and I keep trying to hold the button for 30 sec and it's not working. My kf hasn't turned on for about a week and I tried charging it thinking it was dead and that didn't work either . I don't know what to do :'(
by
Thank you so much. This worked perfectly.
by
Mikusan, those solutions almost never work in most situations.
by
PART 1: PROBLEMS WITH LOCK-UPS WITH KINDLE FIRE DEVICES
If the green light is on or the battery icon shows it as being charged, it is unlikely the battery. If it turns on, but locks up it should still show the clock running. I had a similar problem with my Kindle Fire. It was constantly locking up on me. It would work fine for awhile, and then it would lock up and I would not use it for a period of time. It was really frustrating because it is like carrying my library of books and apps with me for ready use whenever I needed them. I searched the Internet and discovered that a lot of people have reported the same problem with their Kindle Fire devices locking up on them, even the newer models. I have KF First Generation (KF1G). It is a marvelous toy when it works, but when it locks up it really gets frustrating. I'm sure Amazon and other websites have appropriate anti-virus programs checking the various books and apps that are filtered through their servers, but I have come to the conclusion that some of the freebies with ads or trial programs may be the culprit because every time I download one of those programs, especially games my KF locks up on me at some point. It is possible that some of those freebies have malware, viruses, Trojans, or other similar programs that could be the cause of some of these lockups.
END OF PART 1.
by
Show 12 more comments
Add a comment
Hi all - had the same issues discussed. Dead screen, would’t recharge, holding the power does nothing.
However it seems to fix itself when I plugged it into the desktop PC and is now charging away from that. Give that a go before you stick knifes in it :-)
Score 14
10 Comments:
Thanks , had same issue but plugging into car charger as opposed to mains had the same effect. Now charging normally
by
thx for that info i will try both suggestions!
by
this did not work it would warn me if the battery was low
by
Thank you to the wonderful people who told me how to fix mine. What a terrific group.
by
To all...thank you. I plugged into PC as suggested and all is well
Charging suggestion.was the ticket
Hats off peeps.
by
Show 5 more comments
Add a comment
To unlock the Kindle device, the easiest and fast solutions is reset your Kindle device. Press and holding down the power button for 20 seconds or more. Then turn the device back on by hitting the power button again. If this doesn’t work the first time, you can try holding the button down for 30 seconds or more. Most of the time, this will be all you have to do to make the Kindle Fire work again.
Score 13
5 Comments:
Thank you! This worked and I'm up and running just fine!
by
Thank you sooo much my 6yr old had 1 last year and i just assumed it broke, so i bought a new one. This years the battery died yesterday today it wouldnt on, so read after googling your msg, ie pressed power button 30 secs then off then on for 3 seconds left charger in, didnt work but 2nd time it did !!! Not immediate affect but after around 1 minute of leaving it on charge from pressing the power button it came on !!! Over the moon its charging now, 1 less prezzy i dont need this year.. i wonder if kindle have this so u buy a new one sooner!!! Makes u think !!! Happened SAME month this year an last with the newest kindle fire hd 8 is this years new one ..
Thanks guys !!!
by
:( mine wont work
by
mine might be to old i got mine 5 years ago
by
Put my kindle in freezer in a Ziploc bag. Turns on everytime!
by
Add a comment
I had a problem similar to yours but all I had to do was hold the power button down for about 15 seconds then let and start pressing it repeatedly and my kindle came back on
Score 8
11 Comments:
ive been trying this method and its not working for me :/
by
Not working for me either. Frustrating! I know the battery is fully charged. It was on, then locked up. Finally got it to shut off, then nothing. I tried plugging it back in, and don't even get the tone that it is charging. I tried 15 seconds, 30 seconds, even a full minutes and still getting nothing. This is my 3rd kindle. GRRRRRRRR
by
my amazon fire 7 wont charge but when you hold the power button you can hear it.i've tried hold the power button and low and loud sound buttons but it still wont turn on if you have a recommendation please contact me at flegeo980@apps.wylieisd.net thx so much!
by
@blue_queen i have the same problem
by
This did it for me. I had been holding it down. I started pressing power repeatedly after reading this and it came on.
by
Show 6 more comments
Add a comment
My fire device would not turn on after charging all night long. I did all the trouble shooting in this blog.
Guess what made it work…….i hit it with my flat hand.
Back in business
LOL so funny!
But im glad because it was a gift.
Score 8
8 Comments:
OMG thank you so much for the tip!!!
That really worked just hitting it flat with my hand all it needs to do now is charge.
by
THIS WORKS. Tried the knife method, tried 30s, tried volume down... nothing. Tried this, slapping the front then the back and it turned on after pressing the power button. Thank you!
by
Brilliant! Have been trawling through forums for a fix and this worked!
Fire would not turn on at all even after being charged overnight, whilst on charge to mains power it would repeatedly flash up the Amazon screen, but go no further, so could not do a soft reset or hard rest, charge light would not show as green or red, despite it being left it charging overnight to mains power.
So I was on the verge of giving up and throwing in the bin and got to this post - the good old 'give it a hit'!
Laid it screen down on a flat surface and gave it a very hard slap with flat hand, and as if by magic, the device has now switched on as normal!
Was completely flat at first but now at 4% and taking a charge, so guess there was some kind of charge / hardware issue that let the battery go completely dead and not let it take a charge again?
I should add, this is the kids version with the protective rubber sleeve, but all the same it does get bashed around so this probably does not help its life expectancy at all!
by
Omg this hitting $@$* really worked... am so happy i dont have to buy another 1 for my daughter
by
I tried everything.......hitting it......who knew!!! It really did work.....Thanks!
by
Show 3 more comments
Add a comment
Your charger might need replaced. I have an Amazon Kindle Fire, and sometimes the charger doesn't plug in right. I suggest trying out a charger somewhere to see if this is the problem before getting any new parts.
Score 4
4 Comments:
yeah AC adapter was the culprit
by
Does that mean I was right? LOL
by
my generation 7 kindle died and won't come on I got it to show the charging symbol and the low battery symbol like you know when it dies and now it won't come on can you plz help.
ive tried multiple ideas
by
Had the same thing! I tried plugging it into the wall socket and got the green symbol but didn't leave it plugged in. Tried again, just legt it plugged in and noe it's charhing!!
by
Add a comment
jonathan jones, the Kindle does not have a hard drive. It stores information on memory IC's. the only way to get any information off it would be with an expensive NAND memory reader and the right software. Most likely not an easy DIY'er job. I would start with the battery. You can use a multimeter and see what power you have on it and if it charges by checking on the battery contacts with a multimeter while plugging it in.
Score 2
4 Comments:
Where can we get it repair? Does Amazon have repair center?
by
Help it happening to me rn
by
so the memory card isn't going to store the memory? fire hd 10
by
tank u so much my kindle was locked for a week now ur a life saver
by
Add a comment
try to hold the power button for 30
Score 2
2 Comments:
I tried the on button for fifteen seconds but it still wont come on.It has a light screen not black
by
On wait it is coming on and is now working
by
Add a comment
Put it on charge. Then after 5 mins or so hold the on button for 30 seconds or longer then it will turn on. Your welcome. However is this doesn't work then your kindle fire needs to be fixed in the shop.
Score 2
4 Comments:
omg you are an angel sent from heaven thank youuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu
by
and the next day it did the same thing......here we go again!!
by
Yabba dabba do, works for me too!!!!!
by
theres so much chatting
omg
by
Add a comment
Hey, guys I actually found a solution for this error.
https://www.errorsolutions.tech/error/ki...
follow solutions No.2 it works perfectly for me.
Score 2
2 Comments:
what generation is your kindle?
by
this worked for me.
by
Add a comment
I just tried the first thing that came up in Google search for Fire Tablet wont turn on. Hold down the power button for 20-30 seconds. Then try turning on like normal. It worked the first time. No need to disassemble.
Score 1
Add a comment
I found the issue. The motherboard died
Score 1
1 Comment:
mine will make the sound like its showing the dead battery display but it wont show the icon
by
Add a comment
So we have noticed over time the solder joints on the USB charger are getting loose or disconnected. So a fix we found is to add flux to the solder joints then re heat the joints and in some cases we had to add new LEADED solder to make the connection work again. Its as if the power and ground pins are not connecting to the pads on the boards. Try this and if it works then like it and share it its seems to be a issue on all the Kindle Fire Tablets.
Score 1
2 Comments:
Had my Kindle for about 4 years now was working on it when it just went blank. Black screen tried to reset it won't reset tried holding the button down won't reset had it charging for about 1 hour won't charge I don't even get a light up on top not green or red. Now what do I do
by
There is a way you can flash it I had to find 30 virus programs till I found one that actually worked but thank God for virtual machines you can delete. There is a method I will look in my programs see if I have it and send you a Google drive link. It flashes just about any Kindle back to stock.
by
Add a comment
Abusing the device isn't fixing it. The problem is sub-standard quality. What do expect for $50?!? Battery replacement is gonna cost you$30. Other repairs likely more. Cut your losses and just buy a new one. Unless of course you have unreplaceable data on it. Which shouldn't be the case, as Amazon provides a limited cloud space for backup as well as G-Drive. My step daughters 5th gen took a crap, I replaced the battery and still no response. I suspect a hardware failure. That's why I'm even here in the first place.
Score 1
Add a comment
If you are sure that it is fully charged try holding the power button down for about 20 seconds or so, release it, then push it again and see if it comes back on.
2 Comments:
Holding the power button doesn't &&^&^$^ work no matter how many times you say it dumbass
by
Well it got mine out of a frozen state with the flat battery icon
by
Add a comment
My 3rd Generation Kindle Fire went dead. Won't seem to charge or just has a black screen? I had two. Here's what I did. I carefully slipped a sharp knife in the slit where the case splits and took the back off. I then slipped the connector for the battery out of its receptacle. I slid the metal knife edge across the metal contacts on the battery plug and point what matter does it make? This happened to both of mine exactly 30 days after the warranty ran out. This worked on my wife's new Kindle also.
1 Comment:
would this work for generation 7 kindle fire?
by
Add a comment
My kindle fire hdx 8.9 64gb 3rd gen just black screen froze and shut off while charging. (Battery was 59% charging), i have data i need to get off and all i was doing was watching YouTube video. It over 3 years old to and battery been fine. I did complete discharge yesterday but it charged back up to 100% overnight. Now it dead. Currently charging it on usb port overnight to see if that revives it. Please help.
Add a comment
Well hello and sorry for your complaint. I had the same problem too. Try to charge your tablet with it proper charger and let it sit if you don't see the lightning bolt pop up then maybe your tablet battery in the back has worn out.
Add a comment
Had same issue. Battery flat , wouldn’t charge, adaptor ok as charged 2 x other items. Plugged into car charger 5-10 mins, started charging. Now charging normally on mains.
1 Comment:
My kindle has been charging for a day.
by
Add a comment
Similar issue but mine gets amazon logo for about 3 seconds then goes black again. And, There is no red or green light .
1 Comment:
Me too. I've factory reset it remotely. Boots up, gets to the language selection screen, and immediately turns the screen off. Won't come on after. Can't select anything.
by
Add a comment
I tried all your ideas but nothing worked I tried plugging it in somewhere different. Literally nothing worked
1 Comment:
Well, I was just on my kindle fire, and it was working ok, then it just shut off, and it's not turning on . It did the same thing before, and I fixed it, but now, it 's doing the same thing again, and it's been charged, I just can't turn it on again. I tried pressing the two buttons for a few minutes, but nothing happens. What's going on with my tablet , does anyone know what I can do to fix it again ?
by
Add a comment
Volume up button and power button…..press and hold at same time and it should reboot.
2 Comments:
Amazon comes up, then fire but want respond
by
Does this method actually work? :(
by
Add a comment
If no power and literally dead tablet I believe the motherboard dead and needs replacing
Add a comment
I tried all the troubleshooting tips and none of them worked. This issue is everywhere. Why isn’t Amazon posting an official response with a fix to this issue?
Add a comment
Add your answer
jonathan jones will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 58
Past 30 Days: 281
All Time: 414,839
