My kindle won't turn on. Is it the battery?
I walked in one day and my kindle fire hd refused to turn on. I've made a visual inspection of the motherboard and battery nothing seems out of sorts. Is there a way to tell if the battery itself is the problem or if there is something else i can try. I am not terribly concerned about the fire itself, there is a good amount of data on the harddrive that i need to get off. I'd love to get the fire working again but the data is more important. Is there anyway that i can get the data out? or tell if the battery is working so that I don't waste my money trying to fix it.
42 Comments
Help me now I need help
by Jamesreed
Bang it on the ground, then hold the button down thirty seconds. Press the button
once again.
by doodleunicorn
My 3rd Generation Kindle Fire went dead. Won't seem to charge or just has a black screen? I had two. Here's what I did. I carefully slipped a sharp knife in the slit where the case splits and took the back off. I then slipped the connector for the battery out of its receptacle. I slid the metal knife edge across the metal contacts on the battery plug and plugged it back in. My Kindles both immediately booted up and worked fine. Pretty sure this voids the warranty but at this point what matter does it make? This happened to both of mine exactly 30 days after the warranty ran out.
by amlpal
I also tried passing a metal knife across battery contacts after reading this post and it really worked right away instantly on my son's 3rd Gen kindle fire in which froze on three different occasions through the years which I fixed using 30 second power button hold or holding volume down/power button master reset I even personally changed its broken usb port last year. Thanks who ever you are it really worked after other proven methods were not working anymore this time around
by Carlos Torres
My kindle Fire has gone dead and all my efforts to revive it have failed. what is distressful is that Amazon which is selling these devices in India is least concerned about it,and i am told they donot have any service center in India
by Azeezulla Baig
Show 37 more comments
