Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
OS X Won't Boot
Disk Utility Report:
Verify volume "Macintosh HD"
Checking HFS Plus volume
Checking Extents Overflow file
Checking Catalog file
Invalid sibling link(red)
The volume Macintosh HD needs to be repaired(red)
Error: The underlying task reported failure on exit(red)
1 HFS volume checked
Volume needs repair (red)
Score -1
Add a comment
Chosen Solution
Your drive may need to be reformatted using the write zero option to map out any bad blocks. This does erase all the data.
Score 2
Add a comment
Try TechTool Pro for macs if you've already tried all of the usual fixes
Add a comment
Add your answer
Cedric will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 233
