Model No. A1367 / 8, 16, 32, or 64 GB capacity
Why won't my iPod screen stay in all the way?
Recently, I cracked my iPod. So, I took it into a place called Re-Tech, and they did a pretty good job replacing it. But a few days later, I noticed the screen was popping out. So once again I took it back in and just got it back today. Not but 5 hours later, it's popping back out. I don't know what they did, if it's whatever they used to hold it down, somethings wrong inside. Everything works fine, it's just the screen wont stay in all the way. I don't know if I can do anything myself to fix it, or if I am going to have to go in and pay another $120 to get it fixed. Really irritated, so please help!
Score 1
Add a comment
From my experience, the metal plate at the top of the screen is put back on, it never works again once its removed from the screen. If thats on there, then thats your problem, if its not, then its just the poor adhesive they use. Ive had this problem in my store when I fix ipods. I found out the solution is to take super glue and put a DAB on each corner and put small clamps on the corners to hold it down. If theres pressure on the LCD, thats probably because they didn't secure the metal plate underneath all the way down.
Add a comment
This is a common issue with the 4th Gen iPod replacements. Basically, all that is holding the screen on is double sided tape, and a very thin strip of it. There are a bunch of methods to help get it to sit right and stay, but it is a crap-shoot, and just bad planning and design in the first place. Fortunately, the later Apple mobile devices use screws instead of adhesives.
Add a comment
Add your answer
Alex will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 938
