The Motorola Droid RAZR Maxx is a version of the Droid Razr carrying a higher capacity 3,300mAH battery.
21 Questions View all
How do I fix a green screen on my Razr?
I dropped my phone about 6 months ago and the screen turned blue. After a few shakes it went back to normal.From then until now, when I turn it on it is green until I shake or tap it on something. It is taking longer and longer to go back to normal. Does anyone know what the problem might be or how to fix it?
Score 1
1 Comment
I dropped my phone on wet ground with the cover on. It seemed fine and not wet. Later the volume controls started muting and then the screen had a green tint. Rebooting in safe mode did nothing and turning it off for 12 hrs did not help either. It is a moto z4. I also have a white very thin line on left of screen border now. What is causing this and can it be fixed. My phone is sealed so I cannot just take the back off and check any wires or connections.
by
Add a comment
Chosen Solution
Cynthia Miller, this could be a loose connection on the LCD as well as the connector. I would suggest to disassemble the phone and to take a look at the connectors, cables, and components of the logic board. If they look okay, replace the display. this video should help in getting into your phone.
Add a comment
thanks i will try it and see if it works
Add a comment
Add your answer
Cynthia Miller will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 56
All Time: 8,392
