Repair guides and support for netbooks produced by Asus, including the Eee PC line.
windows 8 Instalation problem
I have tried to reinstall windows 8 on the ASUS Vivo book, Made a bootable usb disk and deleted all the partitions on the drive including the manufacturers partitions to start the installation. The only problem is when installation reach 15 % it gives me an error message: Windows cannot install required files. The file may be corrupt or missing. Make sure all file required for installation are available. and restart the installation. Error code 0x80070570
I read all threads and advice but nothing helps, please help asap
Score 1
Add a comment
Chosen Solution
If your getting to the 15% mark on the download everything seems to be fine on the Flash drive end and it's partitions. I would try to re-image the windows 8 software all over again and re-install on the Flash drive. Something might have cause a few of the files to go corrupt during the imaging process.
Score 2
Add a comment
I have come to realize after using memtest that I have faulty ram, my conclusion was that this is causing the installation to fail? Could this be? The problem is this laptop has onboard ram so I cant replace or repair it. Is there any suggestions other than buying a new motherboard?
Add a comment
try going into bios /security/secure boot control and disable.
it's secure boot that's giving you the problem.
Add a comment
Add your answer
Andries Kruger will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 744
