CPU fan runs full speed
My iMac CPU fan runs on high all the time.
I have done the usual SMC. PRAM resets with no luck. I have tested the fan and the control circuit an I believe they operate OK. I think it may be the LCD temperature sensor that is at fault but would like to prove this before I buy another.
Any ideas how to do this? I will measure the resistances between all pins and post them in the hope someone can test their system and compare measurements.
It's a 4 wire device... is it the same as the Ambient sensor??
One last note, I booted the system w/out RAM and noted that the CPU fan runs at normal low speed. Re doing this with the LCD temp sensor disconnected the CPU fan runs on high....
11 Comments
I have now replaced the LCD sensor, run AHT and there are no faults detected however y fan still runs on HIGH... tried SMC and PRAM reset too to no avail. Hoping ASD may help...
by Richdave
So I have run both OSX and EFI versions of the ASD 3S123 and neither report any errors and both are able to drop the CPU fan speed down to the normal idle speed during tests so that confirms (IMO) the h/w is working fine!!
by Richdave
So the restore disks finally arrived and I did a clean install of the 10.5.4 and apps to put the system "back to factory" in the hope it may help this intractable issue I have with the CPU fan running.. Lo and behold whiel I am installiang the fans run full speed but once I complete the install and get to decktop they are nice and quiet. I have a moment of joy while I install iStat and then watch... over the next few minutes the fan creeps up to full speed again... ARGH!
by Richdave
When the fan creeps back up to full speed, what are the temps on your sensors as indicated by iStat? Specifically what are the CPU and GPU core temps?
by Eric Drust
CPU is 26 and GPU 34, CPU HS is 27 and GPU HS is 31, PSU is 65
by Richdave
Show 6 more comments
