Model No. A1367 / 8, 16, 32, or 64 GB capacity
907 Questions View all
iPod touch sleep button jammed/screen wont work
Hey!
I placed my ipod in my pocket today and after taking it out I found the sleep/awake button jammed. It was cleaned and there are no visable things stuck in there. Yet it wont unstick. It got to the point where the screen itself doesn't work when touched. Th volume and home buttons work fine. It is not under warenty. Is there anything I can do?
Score -1
Add a comment
1 Answer
Chosen Solution
Hi !
One of the epicest fails of Apple on iDevices is the power button. This is only a plastic/metallic button that presses a spring contained in a sensor cable. After appox (with a normal use) 1 1/2 - 2 years, this spring may no longer work and your power button may look stuck.
I had this problem on many 4th gen iPods & iPhones but fortunately, the sensor cable can be replaced easily if you can keep focused and patient for a whole our. Follow the links below to find all you need.
Hoping to have helped you !
Give us somme feedback,
Vincent
p.s. : you may also enable the AssistiveTouch mode in your accessibility parameters
iPod touch (4th Gen) Volume/Power Cable
iPod Touch 4th Generation Volume/Power Button Cable Replacement
iPod touch (4th Gen) Volume/Power Cable Image
Product
$14.99
Score 1
Add a comment
Add your answer
redwolfarky will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 7,206
