7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
220 Questions View all
screen jumps after replacing digitizer
I replaced the digitizer on my ipad mini and now if you pick up the unit or move it in anyway the screen will jump all over the place. it is like the digitizer has a short in it. i bought the digitizer with the c-1 connector already soldered in. this is the second digitizer i have tried. both are doing the same thing. please help me!!!!!!! thanks.
Score 3
4 Comments
My iPad screen also jumps a lot.REPLACE THE CHARGER CABLE.
Use canned air to keep the iPad connection area clean. PROBLEM SOLVED
with proper new charger cable. Charger cable must fit iPad securely and properly. Not all cables are created equal.
by
The charger cable can not be the problem if the problem occurs when it is not plugged in.
by
I had an iPad where the web page (e.g., youtube) keeps switching videos/loading new pages without even touching the screen. The digitizer is likely shorting out. If it is a new digitizer, then it is likely either where the internal cable connects to the main board, or it is simply flawed manufacturing with the sensors themselves.
by
I had this on ipad 4th gen, its nearly always the ribbon from logic board to screen where it leaves the case and joins the screen...this is where it bends and if its a cheap screen its made of cheap brittle plastic...it can only be bent once when putting the screen back on...if you try putting the screen on and off the case to test it , it will be enough to split the ribbon..
by
Add a comment
Chosen Solution
This is really wired! I would go and double check your connections. Also make sure that none of the wires or ribbons are pinched. This can cause all sorts of crazy things.
Add a comment
Most Helpful Answer
I had this problem and used electrician's tape to tape of the exposed metal around the bottom and it solved the problem. I theorized it was shorting when metal touched metal. But I've also read that magnets can cause this if they get to close to the digitizer so if you put the rare earth magnets back onto the glass' underside, make sure they are away from the digitizer itself. Good luck!
Score 2
Add a comment
Yes as the guy above said just put electrical tape were the soldering of the home button is and that will fix the issue
Score 2
2 Comments:
I covered it all up and still didnt work. when i press down around that area it gets worse so it has something to do with it but the black electical tape has done nothing
by
Cover the connections on the left and right of the home button on the digitizer. If that does nothing, then it's possible that the ribbon is pinched, or loose.
The last thing it could be is damage to the ribbon, or a bad digitizer. Neither are easily fixed.
Look around where it connects to the screen and look for a small tear. Any damage to the ribbon cable will cause this ghosting issue and get worse when you press down on the screen around the spot.
by
Add a comment
I have fixed a lot of iPad minis and everyone here is right. You need to make sure those areas are taped, which it looks like you have. However, let me tell you a place to tape off that you might miss. I was working on an iPad mini once and long story short I couldnt get any digitizers to work with it. They all had ghost touching etc. I finally disconnected the digitizer for the 100th time and looked on the back of the connector that connects to the motherboard. There are what looks like 20 plus solder points. Make sure that this part has kapton tape or some type of tape on the bottom of it. If it does not, the back side will ground out on the inside of the iPad mini. There is usually an adhesive pad in this area from the factory, but it can get pulled off when removing the original broken digitizer.
Score 1
Add a comment
I have a similar problem.It happens after a while that ipad is on, not right away.
Add a comment
@lee white hi,i was working on an iapd mini there 5 minutes ago.had the same issue i would suggest you to do the tapes again ,basically i covered the whole bottom border except for the home button and that worked for me .so maybe give it another go .good luck .
Add a comment
if you are using extra double sided tape beside of screen adhesive don't use
Add a comment
Add your answer
bobby will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 36
All Time: 13,487
