The Linksys WRT54G (and variants WRT54GS, WRT54GL, and WRTSL54GS) is a Wi-Fi capable residential gateway from Linksys.
problem with router connection
Dear Sirs,
I have the following problem with Linksys router wtr54gl: after an unsuccessful attempt to install new software, I have no communication with the Internet and can not reset the router to factory settings.
Expect some advice.
Credit: O. Boev
1 Comment
Oghi Boev, when you say "attempt to install new software" are you referring to installing new firmware for your router? How did it fail? How did you try to do it?
by
Add a comment
Chosen Solution
You must connect to the router via Ethernet cable for setup/upgrade. If you pooched the upgrade buy a new router... software fixes/hacks are not really our thing here.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Add a comment
This answer was originally to another question.
Here's the Linksys support page for your unit WRT54GL Wireless-G Router It has all you should need to answer your questions.
Add a comment
Try by resetting your router and re-configure it again. Please note that your all saved setting shall gone once you have done hard reset so i would suggest if your using ADSL then get your PPPoE account setting from your ISP first and then do this.
Add a comment
Add your answer
Oghi Boev will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 622
