The RIM BlackBerry Curve 8520 is a sleek entry-level smartphone that delivers some nice design enhancements and great performance
30 Questions View all
x on the signal bar with any sim card
with original sim card or any other sim card there is an x on the signal bar, so i am presuming that the signal receiver is broken. i have opened up the backberry and im looking at the chasis or the motherboard. Where is the signal receiver and what does it look like?
Score 1
Add a comment
Most Helpful Answer
Couple of things:
First, I read your previous question and I'm not convinced it is an antenna fault. However, to answer your question the antenna looks like this and costs about $2.00.
Second, I believe, if it is a hardware issue, that it may be the SIM card reader itself. If that is the case you may need a new logic board.
Third, the little "x" in the signal area usually means that it is still actively searching for a signal, but is not in range of one. So it is possible that since you were changing settings for unlocking the phone that it is searching for a signal that is is out of range of. If this is the case it means your hardware is all perfectly fine and you have a software (settings) issue.
Score 1
Add a comment
hello i have cell phone blackberry curve 8520 icant type keyboard thank you.
Add a comment
Add your answer
kayleigh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 521
