Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
Mid 2009 A1286 Battery Upgrade
I have a mid 2009 MBP and it has the 4hr battery in it... does the new MBP 15" Early 2010 battery's fit into this model? I would like to upgrade to the 7Hr battery (apple made the new 7hr battery model 2 weeks after i got this 4hr model)
Score 1
1 Comment:
No one knows, if a later 2009/2010 model 15" MacBook Pro battery will fit into a mid 2009 model?
by
Add a comment
If the part numbers match
they are compatible.
'''If this answer is acceptable please remember to return and mark it.
Good Luck,
N.
Add a comment
Yes
The part numbers are identical (3ICP5/81/77-2). As machead says, this means that they are compatible.
Add a comment
they are two different batteries, from my research, the mid 2009 15" MBP has a 73-watt-hour non-removable lithium-polymer, and the mid 2010 15" MBP has a 77.5-watt-hour non-removable lithium-polymer. They appear to be the same size, but only question is will the mid 2009 MBP accept the 2010 battery and its larger capacity. If it is compatiable, i would get the 2010 battery hands down. I mean if your gonna pay the same price for battery replacement, might as well get the one with a slight more improvement. but knowing apple, they only want you to use the battery that it was sappose to use for.
Add a comment
The unibody composition also makes these new laptops easier to service and fix, and great for do-it-yourself types who, in the past, have lamented how difficult it was to do things like swap out the hard drive or battery. The redesigned MacBook Pro makes it very easy to access these particular components–just push the lever on the bottom of the case, and you’re in. Upgrading RAM, though, requires removing eight screws
http://www.applereviewed.net/tag/macbook...
Add a comment
This battery only fits 2009 Model
Add a comment
Add your answer
John will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 23,659
