Model M7572 / 400 or 500 MHz G3 processor
46 Questions View all
Will not boot up despite active power soure
I have tested the power source and it works well. I plug it in and press the on/off button and nothing, not even a faint noise, occurs. Everything seems dead. From past experience what is the most likely cause and is it worth trying to find a fault and repair it?
William
Score -1
Add a comment
1 Answer
Chosen Solution
On board dc-in circuit, faulty power button/damaged top case. If someone has been in it before you they may not have completely or correctly reassembled it.
It will take a lot of troubleshooting, examination to determine where the first or major problem lies. If the battery is charging that could eliminate the DC-in board as suspect.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Add a comment
Add your answer
william isbister will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 159
