The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
E82 error code on 360 S
I have a E82 error code displayed and a Red LED light at the 360 S console. What should I do to fix it ? Tks
Score 8
3 Comments
E82 solved - reheat cpu 350 degrees C / 5 minutes.
Working very well now.
by
my xbox 360 S keeps on showing red lights
can I have some help
by
it says E82 and I have tried to fix it but it still says it
what should I do?
by
Add a comment
1 Answer
Chosen Solution
Ben Ho, "E82 has been a common error on the slims for some time since release, E82 error is the GPU has overheated and come unseated from the main board. Try to turn the console on without a HDD in place. The HDMI cable also may be a reason so try to use a standard AV-cable. If the console still displays the error, then you may have to reflow/reball the GPU. Also, check with MicroSoft and see if it is still covered under warranty. Hope this helps, good luck.
Score 7
5 Comments:
why is the xbox360 have red rinhg of death
by
@andrecious32 are you asking this as a general question? You just want to know why the Xbox360 was plagued by the RROD?
by
@David Garcia not sure about HHD but if you are ferring to HDD that stands for Hard Disk Drive. Here are the guides to work on your Xbox Xbox 360 S
by
That might be it. The problem I’m having is everytime I plug in an AV cable or a HDMI cable, the power button in front turns red@oldturkey03
by
How did you fix it?
by
Add a comment
Add your answer
Ben Ho will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 145
All Time: 56,419
