Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
SSD not recognized in system
Well I have the same problem, I bought a Kingston HyperX SSD SATA 3. I replaced the Apple HDD (Toshiba) and the SSD isn't recognized, even in disk utility. I also tried with a Hitachi HDD it also is not recognized, the only HDD recognized is the Apple Toshiba drive.
I have a MBP mid 2012
Any idea?
Thanks
Score 1
Add a comment
Chosen Solution
Well, I changed the sata cable and it works now :)
Score 2
2 Comments:
what type of cable did you change it to?/
by
It depends, you need to search the data cable for your specific macbook
by
Add a comment
See this similar problem. It could also be an EFI/driver problem. Have you checked the manufacturers support site/knowledge base?
If this answer is acceptable please remember to return and mark it.
Score 1
Add a comment
Chinese:
我觉得你的 Kingston HyperX ssd sata3 有问题,去更换一个试试吧
English:
I think you have a problem, Kingston HyperX ssd sata3, try to replace with another.
Score -1
1 Comment:
:), the problem was the data cable...
by
Add a comment
Add your answer
Cristian Kodiac will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 973
