The Jazz HDV178 is a sleek, point-and-shoot handheld camcorder with a 10 megapixel video resolution and 11 megapixel still picture capabilities.
3 Questions View all
Is my battery defective?
As with the first question I too am having trouble using my camera. I hook it up to charge and red light flashes briefly then goes solid gree, how ever when I try to use the camera it seems the battery is dead. In order to determine if it is a defective battery I have to try a new one. Where can I get a new battery.
Add a comment
Chosen Solution
Dick Rutter, from your description alone, it does sound like your battery is no longer holding a charge. I would start with that and hopefully it will resolve it. Otherwise there are issues with the charging circuit. Hope this helps, good luck.
Score 1
Add a comment
Hello
If the battery voltage drops, eg, 3.25 V, the camera will not start. then it seems that the battery is bad, which in many cases is so. But it may be that the internal battery is no longer charged. The clips on the battery voltage to the camera can be pushed too far inside which there is no good transfer.
You can try to charge the battery. Voltage to 3.7 volts with an external power supply When the battery voltage, battery back in the camera, in most cases, the camera will do it again, for a kotrte time. The battery's going but a limited number of them. A new battery is the solution in many cases.
Score 1
Add a comment
Add your answer
Dick Rutter will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 20
All Time: 365
