Runs Water All day
This washer will run water all day and never wash the load in it. We unplug it start all over, some times it takes several times of complete restart then it decides to wash. I Hate this washer
Water Inlet Valve
If the washer is overflowing and power is shut off to the washer, the water inlet valve has failed. Replace it.
Pressure Switch
If the washer is overflowing the pressure switch might be defective. The pressure switch is attached to a small tube which is attached to the outer wash tub. As the water level rises the air pressure in the tube increases, once the set water level is reached the pressure switch turns off power to the water inlet valve. Check to be sure the air tube to the pressure switch is clear before replacing the switch.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 4
All Time: 298
