How do I fix the error code E74?
When i got a old xbox360 it was broken and i wanted to fix it so i bought it and when i got back home i plug it in and it got a 1 red light and it was the error code E74
TheDiamondKing55, " E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU." check on here for more info on that. What you have is basically a variation of the RROD. in your case it is not the CPU/GPU that is giving the error, but the HANA chip. A reflow of this chip might resolve it for a while at least. A permanent fix would be to reball the chip. check on herefor some idea on how to reflow and do stay away from purposely overheating your console. Hope this helps, good luck.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 1,562
