A popular graphic calculator released by Texas Instruments in 1996.
12 Questions View all
Why is my screen faint?
My calculator was working fine until this morning during a test the screen turned super faint. It didn't die because I can still (almost) see the numbers.
The batteries are new but I tried other ones just in case.
Any ideas?
Score 2
1 Comment
My TI83 has a similar problem. When I switch ON, the screen has vertical lines where the pixels don't come on. The calculator works fine except for the vertical blank lines. When I use the calculator for some minutes, some of the vertical blanks become functional again. But there are always one or two lines that remain. Some thermal-related problem?
by
Add a comment
Chosen Solution
Janessa, try to adjust the brightness. The contrast on your screen might have reset to dark. You can adjust it by pressing "2nd" and the "up" arrow (or "2nd" and "down" arrow) repeatedly. Hope this helps.
Score 10
8 Comments:
Holy $@$* you just saved my life
by
thank you so much
by
Thanks! That worked great
by
Tried changing brightness/contrast, but the screen is still faint, I am hardly able to see the numerics on it.
Any other remedy?
even unable to find a service centre in Mumbai
by
Just reset the calculator!!
by
Show 3 more comments
Add a comment
Check the battery contacts to see if you have some corrosion on them.
Did you spill anything or stress it with some weight resting on it?
Score 2
1 Comment:
Tried removing and cleaning the battery contacts, but the screen is still faint, I am hardly able to see the numerics on it. Any other remedy?
Any other remedy?
by
Add a comment
Add your answer
Janessa will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 45
All Time: 25,072
