Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
screen hinge loose tilts
Is possible to tighten the iMac screen hinge without completely dismantling the computer. some claim a plastic card pushed in above hinge with release a clip allowing asscess to torx screws ?
Score 5
2 Comments
Any news on this?
by
I made a fix for this. www.themachack.com
by
Add a comment
Chosen Solution
Simple solution: A rubber crutch tip placed between the monitor and the stand holds the monitor position securely and can be very easily adjusted in about 5 seconds. Cost: $0.29.
Score 6
3 Comments:
Simple fix: A rubber crutch tip to support the screen is infinitely adjustable. Mine has been in place at least six months with absolutely no problem.
by
Yep,worked a treat
THANKS
by
What is a rubber crutch tip? Is it the piece that goes at the bottom of the pole of crutches? I’m trying to imagine how that would work.
by
Add a comment
The newer iMacs have a newer foot design.
Your idea of a plastic card was the means to gain access to the foot screws to replace it for a VESA mount on the early '12 and older units. Sorry won't work here.
Here's some background: iMac 27" stand removal.
Given the age of your system I would try going to Apple for repairs.
Score 2
Add a comment
Add your answer
scoot will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 63
All Time: 14,508
