How much to repair a cracked screen?
How much will it cost to get a Motorola G screen fixed? It still works. It's just that the screen is cracked badly!
Shi, the display assembly is around $80 and you can repair it yourself. Check on here for a decent video. Hope this helps, good luck.
If you just need the glass replaced you can get a kit in on line for about $11. Where I live in Florida it is $50 labor if you provide the glass.
can u give me the web sit where i can get the kit for 11$ plz and thank you
Amazon is where I got mine.
only $4.78 on dbxstore
Where is amazon location
Amazon is an online website where you can make purchases for various different things
If you are planning on taking it to a repair shop, it will vary from shop to shop. It may run you approx. $150 parts, tax and labor.
I need one but am in kenya,what shall I do?
They talking about lcd and the screen. Yes that come together but if your lcd is good why you change the lcd you need to order the touch glass but the process is little bit complicated! You have to be very care full when you remove the touch from the lcd and it's break very easily
2 things, one your trying to help someone who's answer was solved. And Two, yes removing the glass is possible, but for someone who has never done it before, its almost impossible to do it without damage. And when they break it, they have to buy the entire screen and add the cost you paid for the glass, and other tools needed to remove the glass and you have more than it would have been to just get the display assembly to start.
I can I get your support by tomorrow
It is very hard just to change the glass anyone who has never done it before will most likely break the digitizer whal trying to remove the broken glass the best method for your first time repair is to replace the glass and digitizer in 1 unit
As ll I need is the fglSssx znc the digitizer right
Why they put them charges on trump that's stupid he was a good president for us
Past 24 Hours: 21
Past 7 Days: 108
Past 30 Days: 480
All Time: 196,435
1 Comment
I cracked the back glass of my Moto G6 and took it to UBreakIFix (US Nationwide Company) and it was $70 USD out the door. They had to order it but they notified me when the glass was in and I went in and had my phone back in less than an hour. They have also remedied other issues I've had over the last several years with no charge! I don't know if the front glass and back glass cost the same, but they indicated it was similar.
by Maggie Herbord
