The HP Pavilion dv2000 Notebook PC is an entertainment based PC produced in 2007.
21 Questions View all
Startup Repair cannot repair this computer automatically - please help
Problem details show:
Problem event name: startup repair offline
Problem signature 01: 6.1.7600.16385
Problem signature 02: 6.1.7600.1638
Problem signature 03: unknown
Problem signature 04: -1
Problem signature 05: SystemDisk
Problem signature 06: 1
Problem signature 07: MissingBootManager
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1033
There are other system recovery options but I don't seem to get them working....Also my dvd/cd drive is broken so I can't install any cds.....
Please let me know if I have any options to get this laptop running back to normal.
Thnx so much for your help in advance
Score 9
Add a comment
Chosen Solution
frank, sounds like you have a missing boot manager. The issues here is that your optical drive is also not working. You could consider repairing that and then reinstall your OS. Or you couyld try and create a boot disk on a USB drive and see if your can repair it. Quote from one Microsoft support engineer's (Azeez N) solution:
Try these two methods suggested to narrow down on the issue.
Method 1 :
To solve the boot issue:
1.Put the Windows Operating System installation disc in the disc drive, and then start the computer.
2.Press a key when you are prompted.
3.Select a language, a time, a currency, and a keyboard or another input method, and then click Next .
4.Click Repair your computer .
5.Click the operating system that you want to repair, and then click Next .
6.In the System Recovery Options dialog box, click Command Prompt .
7.Type Bootrec /RebuildBcd, and then press ENTER.
•If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type Yes. A confirmation message appears that indicates the entry was added successfully.
•If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command.
Bcdedit /export C:\BCD_Backup
ren c:\boot\bcd bcd.old
Bootrec /rebuildbcd
1.Restart the computer.
Method 2 :
You may also perform a system restore Use the Windows Recovery Environment (WinRE) to run System Restore (If System Restore is enabled on your computer)
1. Insert the Windows 7 installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD …". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next
6. At the System Recovery Options Dialog Box, click on System Restore.
7. Follow the System Restore Wizard instruction and choose the appropriate restore point.
8. Click Finish to restore the system.
Score 8
9 Comments:
Thnx for the help OldTurkey....I'll definitely give these a try
by
Thank you so much! The command prompts helped! So thankful to you! Have been working on it for over a week.
by
THANK YOU SO MUCH Olturkey
THANK YOU SO MUCH Oldturkey
by
Hi Oldturkey03,
Had a similar probleme. The command prompt worked great, after switching the attributes of \boot\bcd (attrib -h -r -s c:\boot\bcd).
Thank you very much...
Regards
by
You are the man. Thanks so much,
by
Show 4 more comments
Add a comment
The change of ATTRIB is key, look for that comment before being able to access BCD to rename
Add a comment
Add your answer
frank will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 12
All Time: 115,123
