Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
Why is computer getting really warm?
After I have been using my laptop for a while the computer starts to get very warm and is to hot to use on my lap. I have turned down the power usage settings on things like the screen and processor but this still happens.
Score 2
Add a comment
The most likely reason for this is that your laptop is not receiving proper ventilation while in use. Using your laptop for long periods of time without a cooling pad or external fan will normally cause it to overheat. There may be other less obvious problems that your laptop is experiencing, which can be found in the following link: Dell Inspiron 1545 Troubleshooting
Add a comment
Dell Inspirons have terrible placement of their cooling fans, IMO. (I have one too, which I inherited when its fan overheated and broke and was too expensive to repair...I repaired and upgraded, then inherited it...)
The fan is at the bottom, blowing air down (?!?). So if it's sitting on top of your lap (i.e. like a laptop...) often the fan is almost completely blocked by its contact with your lap.
It's a bad design. I'm quite surprised at how long it has remained that way. The only real solution that I know of is to prevent a snug fit between your lap, or any surface, especially soft one) and the underside of the computer. Prop it up on something so there is airflow to the fan vents onthe bottom.
Otherwise, as you've observed, it gets extremely hot. The next step is for the fan's motor to burn out. This is one of the most common failures for the Inspiron; it requires replacement of the fan. It's a cheap part, but repair involves taking almost everything out of the case to get at the fan. (An aside: this repair does take considerable time and patience, but it's an excellent one to do if you're interested in repair but not terribly experienced. It's not really that hard, just tedious, and the ifixit guide is excellent. And it's a great opportunity to upgrade just about anything in your laptop, since you'll be taking it out anyway. And you'll learn a lot.)
BUT. Prevention is much better. Anything that allows that air flow will do it. If the bottom of the laptop stays fairly cool, you're succeeding. A quick search at your favorite retailer for "cooling laptop stand" will reveal plenty of retail options. Or improvise something. Just be sure there's a grill or cutout or prop beneath that part of your laptop's underside--the part with the vent holes that gets too hot to touch if it sits on your lap. A small investment now will save you a major repair later.
Add a comment
Add your answer
Kyle will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 688
