The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
What is the F26 code?
Washer turns on and starts to add water and then clicks off. The timer works and eventually the F26 starts flashing.
Thank you!
2 Comments:
what is the f 06 code stand for?rlonadier@windstream.net
by
I have a load in the machine and get start there error code F26. How can fix the problem
by
Add a comment
1 Answer
It is a door switch error code, either the connecting wires are loose or the switch is defective. The door switch error code will also be seen if the door is not closed completely. Look fro loose wires first.
1 Comment:
The wires were fine so we are going to replace the door switch. Thanks so very much!
by
Add a comment
Add your answer
Cindy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 5,321
