Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3535 Questions View all
battery smells like nail polish remover
Hey, my phone wornt turn on. I took the battery out and its smells like nail polish remover?
Last time an el cigarette battery smelt like that, it blow up. Sorry for my bad english..
//Thomas Albæk, Denmark.
Score 1
Add a comment
Most Helpful Answer
Do not use the device with a leaking battery, it's dangerous. Remove the battery immediately.
Score 2
Add a comment
This shoulda like the battery has a tear in it throw it away and get a new one do not put back in the phone for safety reasons
3 Comments:
Tear in it? whats that??
by
Means there's a hole in it
by
Its still dosen't wanna turn on.
by
Add a comment
That cause. From your new post you have put up you have put solder all over the connectors . You've more likly shorted the board out
1 Comment:
Theres solder on the point.. but i had solder on it to much so all 3 wass together.
by
Add a comment
omg so does my galaxy s6 the baterry smells like that too!! anyone know what is wrong????
4 Comments:
Lithium batteries, such as many cell phone batteries, rarely leak. But when they do, it can be a dangerous occurrence. Clean lithium leaks with water only using a cotton rag. Dispose of the battery itself before doing so, since faulty lithium batteries can burn your skin or even explode. Do not use any type of alcohol to clean up lithium as it can be highly combustible.
Note that you may not be able to save electronics with leakage from a lithium battery inside them. Using them again could expose you to fire risk, even with diligent cleanup. Water should take care of leakage onto your skin or clothing sufficiently.
by
Is there possibility to use phone again if you repair the phone?
by
not usually, if its very small then a replacement of the battery and any other affected parts should do it
by
do NOT clean a lithium battery with water on a rag are you serious???? lithium plus water = chemical fire that is hard to put out. dont post advice when you dont know what you are talking about. looking at you jimfixer.
by
Add a comment
It only smells this way when I pick my phone up and put it straight to my nose.
What happened: i knew the battery was old and faulty and needed to be replaced so I took a comb and pryed the back off (which was hard bc of the glue) then the battery was smelln sweet like paint or nail polish remover yk. But it hasn't swelled. So what should I do? I can't take it down to a proper recyle place so throw it in the trash? It's still in the phone and I don't want to throw the whole phone away (with all my info on it)
3 Comments:
It's a Moto z force btw (super old, well not too too old. I got a new phone bc the battery would always drop and eventually it wouldn't power on for 2 days. Then weeks later it started working. But over the next year it would only work on a charger till months ago it wouldn't even stay powered on even on a charger.
My dad's having headaches and sinus problems and I'm paranoid it's bc of that smell.
by
Also you can't smell anything unless you pick the phone up and sniff it.
by
@Paris Dawn
Don't throw it in the trash, a battery is made by materials that need to be safely disposed, preferred at a recycling centre. A bad battery may also explode, even if you can't see anything, there may be damage that makes it explode/starts to burn after some time.
If you can't get to a proper recycling centre right now, I would put it in a metal container filled with sand but if you don't have that any other metal container should work.
Regarding the device itself, don't throw it away since the only problem probably is the battery. So if the battery gets replaced, it may just as well work just as new.
by
Add a comment
What you smell there, is probably some kind of methanol/ (DMC). Dont breathe it too much (sniff the battery etc) because this can lead to methanol poisoning. Just carefully remove the battery/go to a phone shop and let them remove it.
Add a comment
Hello,
You should take the battery out of the thing its in, (if its still in something) and then put the battery in water if its hot. If the battery is not hot then you should check for holes. If there is a hole, clean up the hole on the battery with water on a cotton rag, then you should put the battery in the recycling. It is not safe to reuse a broken battery as it could catch on fire or explode. The smell you are smelling is also toxic so I don’t recommend smelling it over and over.
Add a comment
This was rather helpful as I just purchased a used iPhone XS Max and smelled nail polish and started to get worried that my purchase was going to get destroyed
Add a comment
poop
Score -1
1 Comment:
in your face.
by
Add a comment
Add your answer
Thomas will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 109
All Time: 30,550
