Model A1106 / 1280x854 screen resolution
90 Questions View all
Freezes during boot from HDD and DVD
Hello,
my PowerBook G4 1.67 GHz with 2 GB RAM freezed during the boot process after I foreced shoted down by pressed the powerbotten. It always stops at the white screen with the Apple logo and the spinner. The same thing happened while I trying to boot from the Install Disc. The Hardware Test also can´t work.
When I connet it to a mac mini under firewire connection. HD can be detected but hard to read.
I need to replace HD first?? or some serius problem happen?
Does anyone have useful clues?
Best regards
jyer
Add a comment
Chosen Solution
Sounds like a failing hard drive if it's hard to access in target mode. From target mode, back up your user data. Run Disk Utilities and if you can't repair it, reformat and reinstall the system from the Mac Mini if it is not a Intel processor machine. That failing, replace the hard drive. Here's how to do it:PowerBook G4 Aluminum 15" 1.5-1.67 GHz Hard Drive Replacement
Here's some hard drives that will work for you: http://www.ifixit.com/Mac-Parts/PowerBoo...
Score 2
1 Comment:
+ Ralph
by
Add a comment
Try reseating the RAM, and also try to see if you can verify/repair the drive in any way.
Add a comment
Add your answer
Sheing Jye chen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 1,151
