How do I lengthen the front post to raise the handlebar?
The clamp holding the front post will not let loose with the nut loosen. How do I get the post freed from the clamp to raise the handlebar?
You can try to heat it with a heardryer and then quickly add force to the steer (does not really matter in what direction). Have you already tried WD40 (or similar lubricant with corrosion-soluting components)? Sometimes a nice bump with a hammer (and a piece of wood on your stear to protect the paint) helps.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 607
