The iMac G5, powered by the PowerPC G5 processor, was originally released in August 2004.
remove hard drive for data recovery
My friends imac died on him and he bought a new mac mini. Now has found out he cannot use his time machine back ups from his external hard drive because the external hard drive is not working properly.
We would like to remove the internal hard drive and attempt to see if that still works and pull the migrate that info into his new mac mini.
Can you help us Obi Won Kanobi?
Thanks
Pat
ps, I drive by your offices in SLO all the time :)
Add a comment
Chosen Solution
Pull the hard drive out of the old iMac and put it in the external enclosure then use Migration Assistant to move the data. But before you do that, use Disk Utilities from the new machine on the damaged external drive and see if it can be repaired and used.
Score 2
Add a comment
heres a guide for it
iMac G5 20" Model A1145 Hard Drive Replacement
Add a comment
Yep you can retrieve data by yourself. There are programs to do that. For example kroll ontrack easyrecovery.
I used it few times.
Try http://forums.macrumors.com/showthread.p...
But there is a sad news. I'm not sure but most of these programs work with NTFS and FAT32 files systems. I recently tried to find something that would work with ext4 but I was unsuccessful. So, because OS X is using HFS+ file system there could be problem with software. But I can't believe that they don't exist.
To sum up try to google "recovering HFS+ partition" or find program for recovering data that can work with HFS+ file system.
Good luck!
Score -1
Add a comment
I am here to suggesting you to try this brilliant tool which can easily restore your deleted files in just few clicks. to access this tool you have't need any technical qualification. with this tool you can easily repair and recover Data from iMac, MacBook Pro, Air, Mac Mini, Mac Pro Recover Lost or Deleted Partition Recover Data from Multiple Storage Devices.
download this free demo from here:- softmagnat/mac-data-recovery.html
Score -1
Add a comment
Add your answer
Pat Zuchelli will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 1,332
