A Nokia E-series smartphone with a physical QWERTY keyboard and Optical Navi Key. Successor to the E71. Released in 2009.
11 Questions View all
Nokia E72 Motherboard is broken at bottom where it connects charger
Respected Sir,
I have a Nokia E72. And its charging connector part which is at the bottom of motherboard is broken and cut off. Sir, is it possible to fix this issue ?click to see the image
Yours faithfully
Murulimadhav
Add a comment
1 Answer
Chosen Solution
Murulimadhav, if it is broken off, you will need a new board. This is a multilayer board and with the part broken off, those circuits are interrupted. There is no other way to fix it. Hope this helps, good luck.
Score 1
2 Comments:
ok sir, thanks a lot i got it
by
can you tell me where will available the nokia E72 mother hoard .. i find almost all mobile shop in where i am working in ksa and also online but its not available...
by
Add a comment
Add your answer
Murulimadhav will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 949
