Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
How can I find my iPhone passcode?
My iPhone has been disabled for a while now and I want to try to fix it. I already tried what the Apple website says, but nothing works. It said to use iTunes, but I never connected it to a computer in my house after the phone disabled, so that was out of the picture. I decided to try restoring it. It worked, according to iTunes, but the phone is still the same. Finally I tried iCloud and Find My iPhone, but that didn't work either. Is there anyway I can fix this?
Score 1
Add a comment
Put phone in dfu mode connect phone to computer and open iTunes ..
Now press home and power button togeather at same time for 7 seconds then let go off power and keep pressing home now the phone will be dectected in recovery mode .
Now restore and the passcode will be away and you will start off fresh
8 Comments:
what is dfu mode?
by
Do what I instructed you til do that's dfu mode..
Now don't restore from a previous backup cause the code will still be activated you need to setup from new
by
i did that first part but when i let go of power, a few seconds later it restarts, still disabled. itunes does nothing.
by
Ok slide screen so it shows to enter passcode now press and hold the two buttons again now when the screen turns off let go of the power and keep pressing the home button til it comes up in recovery
by
i can't do that because it's disabled. i can only connect to itunes.
by
Show 3 more comments
Add a comment
Any luck?
Add a comment
Add your answer
arjintas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 260
