The dual SIM version of Nokia's C2 series, released in 2011.
9 Questions View all
How do I re install software on my dead Nokia C2-00
I came across this software update notification on my C2 after which i choose download and install. All went fine until the end when it finally restarted and gave a message" contact Service in white and the screen was a ll black. I tried to switch off but it was all non responsive. Now nothing comes on so am here to know if this is salvageable or I just forget it.
Regards
Zed
Score 20
Add a comment
Most Helpful Answer
have you tried to take battery out, and re-insert into phone. What happens if you do that?
Score 4
3 Comments:
..Apparently yes, I recharged the phone just to be sure but even then, nothing came on the screen to show charging was in progress so after that I have removed & reloaded the battery, tried to power it but nothing comes on...
by
Then i would contact warrenty, because if the issue is data corruption or damaged certificate - it can only be fixed in a service center using a flash jig.
by
Ganon pare pag ginwa mo tan
by
Add a comment
Hello, I am also facing the Same Issue :( is There any Solution please?
Score 1
Add a comment
I am also facing this problem in my Nokia C2-00, I removed the battery and again inserted in the phone but it is not working, my phone is just showing white screen.
Score 1
Add a comment
Same Issue i want nokia c200 os software
Score 1
Add a comment
hardware id pass word forgoten .kinly send me nokia C2.00 soft ware id pass word
Score 1
Add a comment
muje mobail pdet karna he
Add a comment
Add your answer
zbundi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 20,147
