The first 8 inch Android tablet by Samsung.
49 Questions View all
LOCA glue in one area or two?
Just to make sure I have this procedure correct, there are three layers, 1.glass 2.digitizer 3.LCD. Is there an application of LOCA between the top two and another between the bottom two? I have this device, getting ready to repair but still getting materials together. Does anyone have an amount of LOCA to do this repair?
Score -1
Add a comment
1 Answer
You are correct. Typically there three layers of a smartphone screen, which are all glued together.
Normally when you replace a screen, you replace all three at once as a complete unit. Some people like to save a couple of bucks by reusing the LCD screen and gluing a replacement touchscreen unit to the excisting LCD scree. Please be adviced, this is a complicated procedure and takes some experience to complete successfully.
While it is possible to buy the glass separately, I don't recall ever seeing a touchscreen unit for sale separately, at least not without the front glass already glued to it.
This goes for smartphones. Tablets are a different story. Typically the LDC screen is separate to the touchscreen, i.e. not bonded to the screen directly. If you want to replace the glass, you replace the glass and touchscreen interface together as one unit - there is no need for LOCA glue here. The glass/touchscreen fron of the tablet is mounted to the front of the tablet using doublesided tape.
Please refere to the following guide: https://www.youtube.com/watch?v=UNXYPS4y...
Add a comment
Add your answer
Rick Givens will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 1,698
