Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
50 Questions View all
Question Closed
Would wwan board affect anything else other than internet?
While replacing the WiFi connector on my iPad 2 CDMA, since everything else used tape, I thought wwan board was attached by tape and I tried removing it so I could lift logic board. In doing research, I have found that I permanently broke and cannot replace this without buying a brand new logic board. Do I need wwan board for anything else? Power button not working and wondering if related or just a coincidence. Thank you.
Add a comment
1 Answer
Chosen Solution
You might not want to upgrade or reinstall iOS after that. The WWAN board is required for upgrading/activating your iPad. Without your original set of two boards, the iPad will be bricked if you try to upgrade/reinstall. There is no way out of this.
Score 2
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 143
