The third generation of the Apple iPad, released on March 16, 2012. Full 4G and Wi-Fi model repair guides. Repairs require heat and careful prying. Model numbers: A1416, A1430, and A1403.
Cellular 3g antenna torn
Hi,
I have replaced ipad 3 digitizer successfully, But while removing the cracked one, Top right side piece next to the front camera got torn. without pasting the digitizer i checked following options and all are working.
3g, wifi, Bluetooth,mic sounds, front and rear camera, volume, mute, power, home buttons are fine.
What should i do? do i have to replace the right side part or just leave it as it is and close it back?
I have attached a picture for your reference,
Kindly reply ASAP as I'm wait your respond top proceed to next step.
Thanks & regards
Mevan FErnando
i tired uploading 2 images but it says unknown error
Score 1
1 Comment
This question was migrated from http://meta.ifixit.com/Answers.
by
Add a comment
1 Answer
Chosen Solution
Tearing an antenna usually degrades its RF performance, your cellular reception will still work but with degraded performance, like maybe slower speed, no service in weak coverage areas, higher power consumption.
The right antenna also serves as the proximity sensor, if it is torn, the cellular module will not properly regulate RF transmit power when your hand is touching the area. So the transmit power may be over safety limit(in my opinion not a problem, the whole idea of cellular signal causes cancer is bullsh1t) or constantly latched to low power setting due to the sensor falsely triggering. This can cause performance issues.
So if you think it is a problem, replace it.
Score 2
Add a comment
Add your answer
Mevan Fernando will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 137
