Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
LED Back Light failure
three days ago, my screen started to flicker and the bottom of the screen began to dim with gray triangles appearing across the screen. I took this to mean that I was having problems with the LED back light power supply. After 5 minutes, the screen went totally blank. I can barely make out the what is on the screen so the system is still working. Since I bought a service agreement, I called Apple and they immediately sent me a box. I received an email today saying that it would cost almost $1,300 because there is an indicated patch that said that the unit had water damage. That was a surprise to me and additional research has indicated that this marker can turn pink due to moisture in the air. I researched iFixit to see if there is anything part to replace that would fix the backlight but all I seem to find is replacing the display. Is this correct? Thanks for the support.
Score 1
Add a comment
Chosen Solution
Yes moisture/humidity has been known to trigger the moisture indicators. You could ask for a reexamination/consideration if indeed there has never been liquid on the machine (there should be apparent difference between a "moisture" trip and a liquid trip... but that may make no difference to the fine legal print)... however if you do not ask for a review you won't be offered one.
Depending on what part of the backlight is bad (your display is LED backlit... the phosphers are on the display, not a separate tube as in early LCD modles) you may need a display, or, a controller. Both are involved repairs.
If Apple would spec what part(s) they intend to replace you might be able to DIY.
If this answer is acceptable please remember to return and mark it.
Replace a display compatible with the MacBook Pro 15" Unibody early 2011 to late 2011 A1286 model laptop. Includes the LCD screen, display cover, bezel, FaceTime HD camera, clutch hinges, Wi-Fi antenna, camera, and display data cables. Image
Product
MacBook Pro 15" Unibody (Early 2011-Late 2011) Display Assembly
$149.99
Score 2
3 Comments:
Thank you MACHEAD, I will be calling them today or Monday to discuss the moisture trip. I believe that it will probably be the controller since I can see the faint screen image which leads me to believe that the power to the LEDS has failed. If things go wrong and I don't want to invest in a DIY repair, I will turn it into a desk unit and apply the repair money to a new IPAD when they come out in November.
by
A logical choice.
by
Live Long and Prosper!
by
Add a comment
Apple announced an repair program 2/20/15. Go here to check if you qualify: https://www.apple.com/support/macbookpro...
Score 2
Add a comment
Add your answer
danatmurphylake will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 7
All Time: 383
