The LG VX5200 is a CDMA flip phone with an external antenna, 32 MB of onboard memory, and a 1000 mAh Li-ion battery.
4 Questions View all
Will I erase my text messages if I repair the logic board
The piece that connects to the charger is broken and I desperately want to recharge my phone to access my old text messages. If I replace this piece on the logic board will this erase my phone's memory?
1 Comment
Im having a simular issue but with a note 4 antenna port. So I replaced the charge port, the glass back (which cracked when being opened), and the charging port but in the process of putting everything back together again for the 3 time. I broke the antenna cable port when snapping off of the motherboard logic board. The antenna cables are fine but the port that the cables snap on to are broken. Does anyone know how to fix it or if I replace the whole part, will I still have my text messages and stuff?
by
Add a comment
1 Answer
Chosen Solution
Trevor, no it will not.
Score 1
4 Comments:
Thanks. Is there a way to just transfer my phone's memory to another VX5200 that works? Or would it be smarter to replace this one piece? Or should I just replace the whole logic board?
Thanks
-Trevor
by
Trevor, ""Is there a way to just transfer my phone's memory " only if you know how to reball a BGA IC. I suggest you get a charged working, start your phone and transfer your files to another device (computer) than you can either resolder a charging port or replace the board. This will depend on your skills and $$$
by
Thank you. I have no soldering skills, and dont know how to reball a BGA IC. What do you recommend? I just want to read my old texts, see pictures, and listen to voicemail messages. -Trevor
by
by
Add a comment
Add your answer
Trevor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 454
