Why not update from 10.5.0 to 10.5.8?
Hard Drive crashed and inserted retail CD disk and ran utility indicated was not repairable. I tried repartitioned (journaled), ran verify and repair and indicated that the volume was ok. It Installed retail 10.5.0 properly. It then downloaded combined update of 10.5.8 but would not install indication that it could not install on the volume. I assume the HD is still bad or there is a software issue. I believe this is the same software CD I installed earlier on this machine. Any ideas?
Add a comment
1 Answer
Most Helpful Answer
You may not have enough space on the HD for a full install. Try a custom install and do not install language packs, printer drivers and fonts you don't need. That may solve your problem.
If this answer is acceptable please remember to return and mark it.
Score 1
Add a comment
Add your answer
clogsdon1 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 116
