The Nerf Vortex Vigilon is a single fire toy gun released in 2011 as part of the Vortex series, model number 32215. The gun fires XLR discs and is green, gray, black, and orange.
Why is the trigger jammed?
My trigger will not move back when I try to pull it. It feels stuck and performs as if it has not been cocked.
Score 4
Add a comment
1 Answer
Most Helpful Answer
The trigger could be jammed for two reasons. Either a disc is lodged in the barrel or there is dirt jammed underneath the trigger. In order to clear the lodged disc, pull the barrel slide located on the top right hand side of the gun with the gun barrel pointing down. The disc should be released and the trigger should pull back. To clear the dirt, you will need to take apart the gun. Clean the dirt with a toothpick or cotton swab. For more information, reference the Troubleshooting guide. You may also need the spring replacement guide.
Score 1
2 Comments:
Did you copy this from Google?
by
@smitajaiswal
Look at the date of the post. You may be waiting a while for an answer
The link is to an ifixit guide created in 2014
Moderator
by
Add a comment
Add your answer
Cara Pew will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 28
All Time: 6,742
