My chuck is not spinning?
Everytime I press the trigger the chuck does not spin, the battery has power, for your information. What possible things could be wrong with my drill?
I had a similar issue. When you pull the trigger the light came on but the chuck would not turn. No sound or smell, the chuck just didn't engage. When I took it apart I found there was a cold solder joint on the red lead to the motor which came loose.
The trigger switch may be bad. It might also be a bad motor or a wiring problem.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 1,726
