2.3L 4cyl or 3.0L V6, 6th Generation
428 Questions View all
How can I get the factory alarm to permanently cut off?
I was trying to arm my alarm and clicking the alarm switch back and forth and since I couldn't get it to go off I believed it to not work. Until I came out of class and opened my door and set the alarm off. After 2 minutes the alarm is supposed to reset itself and cut off. It does. But when I try to enter or exit the car it goes off even when I unlock it sometimes. I tried turning the key in the driver door twice to the left and then twice to the right and the other way. Still to no avail. Any suggestions are appreciated
Score 5
Add a comment
Most Helpful Answer
My lights blinks on and off when the doors open and they don't stop it makes all the lights on the clock dashboard radio when im driving I have to turn on the headlights to get it to stop there a little red light that blinks all the time it never stop it in between the seats
Score 2
Add a comment
You can try resetting the alarm by following the steps in this link;
http://www.wikihow.com/Reset-a-Factory-C...
If it doesn't work, you can pop the bonnet, and remove the alarm relay, located in the fuse compartment (when you open it, there is a drawing on it that shows you what fuses and relays are what). This will act as a temporary fix, allowing you to take the car to a auto electrician, without the cops chasing you, thinking you have stolen the car.
Hope this is of some help
Score 1
3 Comments:
I was wrong it's an aftermarket alarm I believe because I followed that and they didn't work and there is no fuse for it. My uncle uncle unplugged a wire and it cut it off for a while but now it is going off again after I unlocked my door
by
Ah ok, and they would have to be a fuse. I forgot to mention there might be other fuse panels. if not under the hood, try passengers side or under the steering weal, in the foot well.
Also, if its aftermarket, try this http://www.wikihow.com/Reset-Aftermarket...
by
Oh thank you so much how do you no which fuse it is
by
Add a comment
My car factory set alarm goes off when o turn on my car. Pushing control doesn't stop alarm. What should I do.?
Score 1
Add a comment
The alarm does not work but my tail lights keep flashing until I turn the key in the driver's side door twice, now my lights don't work period. Changed the bulbs changed the fuse to no avail.
Add a comment
My alarm on my 2002 Alero is constantly going off. I mean as soon as I turn it off and step foot in the house is going off again. I can't even take a bath and get dressed because it's constantly going off. what do I do can you help me? What is really going on
Add a comment
I have 99 Honda accord. If you don’t want the alarm to go off unlock any other door other than driver door. Its not a fix but it wont go off It gets turned on when the other 3 doors are locked. Before opening your door check to see if the red light is blinking on driver side door. If there is no light blinking than there is no alarm. Otherwise get ready for everyone to look at you. It took me a little bit of time to figure this out.
Add a comment
can you reset alarm without key2002 honda accord.ex
Add a comment
I changed my left key door lock and don’t know how to re set my anti thefti have a 2007 Honda Accord se can any body help me reach me at frankandrade43@yahoo.com
thank you all ..
Add a comment
I had an issue with the central locking on 2001 type r.
Which seemed to trip my clock, ac, dash light and set hazards off and fob/central locking stopped working.
I replaced fuse for clock etc but kept tripping.
Turned out I had to not use remote fob and change the relay next to drivers side fuse board.
Now all is fine but immobiliser is flashing and fob still doesn't work, but it was a quick fix
Add a comment
Add your answer
Adina will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 77
All Time: 65,818
